[GRASS-user] r.watershed speed-up
G. Allegri giohappy at gmail.com
Fri Aug 1 05:21:15 EDT 2008
Great. Things get better and faster!
I've tried on a not so big region. But it was enough:
989861 cells (172286 null cells under MASK, where I have the see)
It has taken about 55 seconds (I don't have time to set up a
profiling), where I asked for drain and visual outputs creation.
The stats are (calculated in OO):
DIFF-VALUES  N.PIXELS PERCENTAGE
-7	56	0,0068
-6	30	0,0037
-5	32	0,0039
-4	49	0,0060
-3	38	0,0046
-2	180	0,0220
-1	914	0,1118
0	814650	99,6422
1	910	0,1113
2	229	0,0280
3	79	0,0097
4	42	0,0051
5	21	0,0026
6	70	0,0086
7	152	0,0186
8	22	0,0027
9	21	0,0026
10	5	0,0006
11	15	0,0018
12	30	0,0037
13	18	0,0022
14	3	0,0004
15	5	0,0006
16	4	0,0005
Things has run better then with the previous version, as >99.6% of
values are equal to r.watershed.
Thanks, a lot, for r.watershed.fast! :-)
Giovanni
2008/8/1 Markus Metz <markus_metz at gmx.de>:
> Hello list,
> there is now a new version of r.watershed.fast where results are even more
> similar to r.watershed. They are still not 100% identical to r.watershed,
> but I can't get it more similar. But it comes with a further speed increase.
> I repeated the test of Moritz with the same commands on GRASS 6.4.svn,
> results are below.
> Moritz Lennert wrote:
>> First test in North Carolina demo data set:
>> g.region rast=elevation
>> time r.watershed elevation=elevation at PERMANENT accumulation=old_accum
>> drainage=old_dir basin=old_sheds stream=old_streams thresh=500
>> real    19m2.744s
>> user    18m41.318s
>> sys     0m1.884s
>> time r.watershed.fast elevation=elevation at PERMANENT
>> accumulation=fast_accum drainage=fast_dir basin=fast_sheds
>> stream=fast_streams thresh=500
>> real    0m18.034s
>> user    0m17.833s
>> sys     0m0.196s
> Absolute times are not really comparable between systems, but relative
> differences in time should be similar. The following numbers are calculated
> with real time. In the test Moritz did, r.watershed took 63x as long as
> r.watershed.fast, i.e. r.watershed.fast needed only 1.6% of the time of
> r.watershed.
> New version: r.watershed took 127x as long as r.watershed.fast, i.e.
> r.watershed.fast needed only 0.8% of the time of r.watershed.
>> Of the 2025000 cells in the map, 1991218 show the same direction, i.e.
>> 98%. Those which have different directions are overwhelmingly low slope
>> cells.
> New version: 2004480 cells, i.e. 99% of all cells show the same flow
> direction.
>> 1833907 cells have the same accumulation value, i.e. 90%, but I guess this
>> is to be expected.
> New version: 1921510 cells, i.e. 95% of all cells show the same accumulation
> value.
> The idea is that a faster r.watershed can also be used for massive grids,
> where GRASS users frequently gave up using r.watershed because it would have
> taken hours or even days. I resampled "elevation" in the North Carolina demo
> data set from 10m to 3m with r.resamp.rst using default values (after the
> GRASS book Section 5.3.3, paragraph "Regularized spline with tension (RST)
> interpolation") to generate a fairly large map and ran the same test on the
> resampled map.
> cells in region : 22,500,000
> The results:
> Speed:
> r.watershed took 5459x as long as r.watershed.fast, i.e. r.watershed.fast
> needed only 0.02% of the time of r.watershed (here 10h2m55s vs. 1m7s, 10
> hours versus 1 minute...).
> Flow direction differences:
> 22288539 cells, i.e. 99% of all cells show the same flow direction.
> Flow accumulation differences:
> 20963653 cells, i.e. 93% of all cells show the same accumulation value.
> Memory usage of r.watershed and r.watershed.fast: maximum of about 940MB
> I don't understand why memory usage increases after <SECTION 1a: Initiating
> Memory> is completed.
> Assuming that there is no longer a time constraint but only a memory
> constraint (although <SECTION 4: Watershed Determination> can take some time
> on large maps with a large threshold value), the upper region sizes that
> r.watershed.fast can process in RAM would be *roughly* for
> 1GB RAM:  14,000,000 cells
> 2GB RAM:  38,000,000 cells
> 4GB RAM:  86,000,000 cells
> 8GB RAM: 181,000,000 cells
> after putting 400MB aside for the system and other open applications.
> Estimate based on Linux 64bit.
> If you want to repeat and analyse the tests with the North Carolina demo
> data set, the new r.watershed.fast is here
> http://markus.metz.giswork.googlepages.com/r.watershed_fast_version.tar.gz
> and the test script is below.
> Regards,
> Markus
> test script:
> time r.watershed elevation=elevation at PERMANENT accumulation=nc_accum_old
> drainage=nc_dir_old basin=nc_sheds_old stream=nc_streams_old thresh=500
> accumulation=nc_accum_fast drainage=nc_dir_fast basin=nc_sheds_fast
> stream=nc_streams_fast thresh=500
> r.mapcalc nc_dir_dif='if(("nc_dir_old" - "nc_dir_fast" != 0),1,0)'
> r.mapcalc nc_accum_dif='if(("nc_accum_old" - "nc_accum_fast" != 0),1,0)'
> r.stats -c input=nc_dir_dif at PERMANENT
> r.stats -c input=nc_accum_dif at PERMANENT
> r.resamp.rst input=elevation at PERMANENT ew_res=3 ns_res=3 elev=elevation_rst
> overlap=3 zmult=1.0 tension=40.
> g.region rast=elevation_rst
> time r.watershed elevation=elevation_rst at PERMANENT
> accumulation=nc_rst_accum_old drainage=nc_rst_dir_old basin=nc_rst_sheds_old
> stream=nc_rst_streams_old thresh=500
> time r.watershed.fast elevation=elevation_rst at PERMANENT
> accumulation=nc_rst_accum_fast drainage=nc_rst_dir_fast
> basin=nc_rst_sheds_fast stream=nc_rst_streams_fast thresh=500
> r.mapcalc nc_rst_dir_dif='if(("nc_rst_dir_old" - "nc_rst_dir_fast" !=
> 0),1,0)'
> r.mapcalc nc_rst_accum_dif='if(("nc_rst_accum_old" - "nc_rst_accum_fast" !=
> 0),1,0)'
> r.stats -c input=nc_rst_dir_dif at PERMANENT
> r.stats -c input=nc_rst_accum_dif at PERMANENT
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
