[GRASS-user] execute commands automatically after start of grass
Daniel Victoria daniel.victoria at gmail.com
Fri Aug 1 08:35:26 EDT 2008
Why not put a test inside .grass.bashrc to check if you are in the
mapset you want R to run?
Something like:
<pseudo-code here - can't remember bash sintax>
if [ $MAPSET = __your_targuet__ ]; do
   r &
  emacs &
fi
Cheers
Daniel
On Fri, Aug 1, 2008 at 6:23 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On Fri, Aug 1, 2008 at 11:16 AM, Jachym Cepicky
> <jachym.cepicky at gmail.com> wrote:
>> hi,
>> you can adjust anything in .grass.bashrc file
>> e.g.
>> #!/bin/sh
>> export GRASS_ADDON_PATH=$HOME/usr/grass/
>> export GRASS_PAGER=/bin/more
> Thanks - that looks exactly what I am looking for.
> But is there a way of specifying a certain .grass.bashrc which should be used?
> The reasoning is that for certain projects I need R and emacs and
> would like to start them automatically, for others not. Obviously, I
> could use a startup script which renames the apropriate file to
> .grass.bashrc, but it would be cleaner to be able to specify it when
> starting grass.
>> jachym
>> [1] http://grass.osgeo.org/grass64/manuals/html64_user/variables.html
>> 2008/8/1 Rainer M Krug <r.m.krug at gmail.com>:
>>> Hi
>>> I am using grass in combination with R, wherefore I have to start R
>>> (or emacs) after starting grass.
>>> Is there any way, to make this automatic, i.e., can I specify a script
>>> which is executed inside grass after it is started?
>>> In addition, I only would like that to happen when I start grass in a
>>> certain mapset and not in other mapsets.
>>> Thanks
>>> Rainer
>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>> Biology, UCT), Dipl. Phys. (Germany)
>>> Plant Conservation Unit
>>> Department of Botany
>>> University of Cape Town
>>> Rondebosch 7701
>>> South Africa
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Jachym Cepicky
>> e-mail: jachym.cepicky gmail com
>> URL: http://les-ejk.cz
>> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> Centre of Excellence for Invasion Biology
> Faculty of Science
> Natural Sciences Building
> Private Bag X1
> University of Stellenbosch
> Matieland 7602
> South Africa
