[GRASS-user] grass64 and qgis-plugin-grass
Gabriele N. gis.gn at libero.it
Mon Aug 18 08:21:41 EDT 2008
Following this recent post:
I installed so grass64 (ubuntu 8.04):
I've just built gdal 1.5.2 (without grass)
./configure --with-ecw=yes --without-grass
and grass (--with-gdal)
CFLAGS="-O3 -mcpu=i686 -Wall" LDFLAGS="-s"  ./configure --with-cxx
--with-python --with-widgets --with-wxwidgets --with-freetype=yes
--with-ffmpeg=yes --with-postgres=yes --with-gdal --with-sqlite=no
--with-motif=no --with-glw=no --enable-largefile=yes
--with-opengl-libs=/usr/include/GL --with-proj-share=/usr/share/proj
--without-fftw --without-ffmpeg --with-readline=no
instead of --with-gdal had to make --with-gdal=/usr/local/bin/gdal-config ?
make install
and then, gdal-grass plugin 1.4.3 (gdal-grass-1.4.3)
../configure --with-gdal=/usr/local/bin/gdal-config
make install
Now I have a problem with QGIS. If I open qgis from grass63 (installed by
the binaries) all is well.
If I open QGIS (installed by the binaries) from GRASS64 :
Loaded / usr / lib / qgis / libgrassplugin.so
qgis: symbol lookup error: / usr/lib/libqgisgrass.so.0.11: undefined symbol:
If I remove qgis-plugin-grass QGIS is fine.
How can I fix?
Thank you
View this message in context: http://www.nabble.com/grass64-and-qgis-plugin-grass-tp19030535p19030535.html
Sent from the Grass - Users mailing list archive at Nabble.com.
