[GRASS-user] Re: GRASS-python-swig
Markus Neteler neteler at osgeo.org
Wed Aug 27 16:07:18 EDT 2008
On Wed, Aug 27, 2008 at 9:32 PM, g_massa at libero.it <g_massa at libero.it> wrote:
> I list,
> I've build python_grass6.so and python_grass6.py with make from MakeFile in swig/python directory but if import the library:
> import python_grass6
> I've that error from python interpreter:
> Traceback (most recent call last):
>  File "<stdin>", line 1, in <module>
>  File "/usr/lib/python2.5/lib-dynload/python_grass6.py", line 7, in <module>
>    import _python_grass6
> ImportError: /usr/lib/python2.5/lib-dynload/_python_grass6.so: undefined symbol: __stack_chk_fail_local
Not sure about above, but:
> Or, in IDLE:
>  File "<pyshell#0>", line 1, in <module>
> ImportError: libgrass_I.so: cannot open shared object file: No such file or directory
suggests that LD_LIBRARY_PATH isn't properly set.
I have:
cat /etc/ld.so.conf.d/grass.conf
/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib
(adjust path to your installation, save as "root" user and
run ldconfig then - I assume that you use Linux).
Markus
