[GRASS-user] speeding up context evaluation...
Hufkens Koen koen.hufkens at ua.ac.be
Tue Dec 2 09:30:39 EST 2008
Hi list,
for a validation exercise I need to extract the class values around certain pixel location.
I have a map with all the locations (numbered) and a map with the validation map.
The code you find below is the one I came up with to get this information (only output to terminal for the moment).
However, this code includes a loop and is terribly slow. Has anyone an idea how to speed things up?
Kind regards,
Koen
---------- my code -------------
#!/bin/bash
# Get context around pixels...
# !!! Bash script only works within the GRASS terminal !!!
# get number of pixels in location file... write to variable $pixels...
pixels=`r.info -r map=$1 | tail -n +2 | sed 's/max=//'`
echo "their are $pixels groundtruth points..."
for i in `seq 1 $pixels`;
do
echo "evaluating pixel $i of $pixels pixels..."
# Make MASK based upon pixel number evaluate one at a time. Mask name is MASK and patch.mask
# after renaming... If kept as MASK it will apply to all operations and is a system wide setting (not wanted)...
r.mask -o input=$1 maskcats=$i --quiet
g.rename rast=MASK,pixel.mask --overwrite --quiet
# create buffer around pixel value...
r.buffer input=pixel.mask output=tmp.buffer distances=4 units=meters --overwrite --quiet
# writes temporary reclass rules file...
echo "1 = NULL" > tmp.rules
echo "2 = 1" >> tmp.rules
echo "end" >> tmp.rules
# reclass context values using rules above...
r.reclass input=tmp.buffer output=context.mask rules=tmp.rules --overwrite
# calculate category statistics for pixel and context location...
r.mapcalculator amap=pixel.mask bmap=$2 formula=A*B outfile=pixel.category help=- --overwrite --quiet
echo "pixel data..."
r.stats -c -n input=pixel.category fs=space nv=* nsteps=255
r.mapcalculator amap=context.mask bmap=$2 formula=A*B outfile=context.category help=- --overwrite --quiet
echo "context data..."
r.stats -c -n input=context.category fs=space nv=* nsteps=255
done
# clean up tmp files...
rm tmp.rules
g.remove rast=pixel.mask
g.remove rast=context.mask
echo "!!!DONE!!!"
echo "#########################################################################"
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081202/97b95054/attachment-0001.html
