[GRASS-user] Re: Gui error behind splash screen
Daniel Victoria daniel.victoria at gmail.com
Wed Dec 3 11:06:22 EST 2008
Finally, everything is working. It turned out to be a mix up of gdal
libraries and gdal-grass plugin installed from the ubuntu
repositories.
Solved everything by clearing all gdal related instalation and
compiling gdal and grass from source.
Now apparently everything is working and I've seen the wxPython GUI
for the first time! Impressive!! Congrats all grass developers for the
well done job
Daniel
On Sun, Nov 30, 2008 at 12:41 AM, Hamish <hamish_b at yahoo.com> wrote:
> Daniel Victoria wrote:
>> another update. I can get into a lat lon location in the grass
>> terminal but g.region -p gives me a segmentation fault
> ok, next we need to figure out why.
> can you rerun with:
>  g.gisenv set="DEBUG=5"
> so it might say how far it got. (set back to 0 to turn off debug messages)
> and then post a backtrace from gdb:
>  http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
> Hamish
