[GRASS-user] output r.out.ascii
Hamish hamish_b at yahoo.com
Wed Dec 10 21:20:38 EST 2008
Hufkens Koen wrote:
> I'm trying to use r.out.ascii to dump a map (or better
> a masked part of it) to stdout. I would then use sed to
> clean up the data so I'm only left with the pixel values
> and no spatial information (don't need it).
in newer versions of grass try r.out.xyz, e.g.
  r.out.xyz fields | cut -f3 -d'|'
for older grass versions use "r.stats -1gn"
Hamish
