[GRASS-user] Re: Landsat data archive now free
Richard Chirgwin rchirgwin at ozemail.com.au
Sat Dec 13 21:11:11 EST 2008
Yann Chemin wrote:
> Hi,
> 1 - on opening GRASS GIS, select create location from georeferenced file
> 2 - use r.in.gdal to import in GRASS GIS.
...works fine...
> 3 - in grass/add-ons look for any of these to correct from radiance to
> reflectance at top of atmoshpere
> - raster/i.landsat.toar
> - gipe/i.dn2full.l5
> - gipe/i.dn2full.l7
Yann, there is something I can't work out from the reference documents,
and the result is that install_yann_grass.sh fails because it can't find
the right directories. Full fail output is:
> Makefile.gipe:13: ../include/Make/Platform.make: No such file or directory
> Makefile.gipe:17: ../include/Make/Dir.make: No such file or directory
> make: *** No rule to make target `../include/Make/Dir.make'.  Stop.
> cp: cannot stat `/home/richard/grass-addons/i.*': No such file or
> directory
> Makefile.gipe:3: ..//include/Make/Dir.make: No such file or directory
> make: *** No rule to make target `..//include/Make/Dir.make'.  Stop.
> cp: cannot create regular file
> `/home/richard/tmp/grass_yann/gui/tcltk/gis.m/': No such file or directory
> `/home/richard/tmp/grass_yann/gui/wxpython/gui_modules/': No such file
> or directory
> ./install_yanns_grass.sh: line 75: cd:
> /home/richard/tmp/grass_yann/gui: No such file or directory
> Makefile:8: ../../include/Make/Module.make: No such file or directory
> make: *** No rule to make target `../../include/Make/Module.make'.  Stop.
> make: *** No rule to make target `install'.  Stop.
Cheers,
Richard
> 4 - use i.atcorr too correct top of atmosphere to surface reflectance.
> good luck!
> Yann
> 2008/12/12 Richard Chirgwin <rchirgwin at ozemail.com.au>:
>>> Message: 2
>>> Date: Fri, 12 Dec 2008 11:13:36 +0000
>>> From: Corrado <ct529 at york.ac.uk>
>>> Subject: Re: [GRASS-user] LANDSAT data archive now free
>>> To: grass-user at lists.osgeo.org
>>> Message-ID: <200812121113.36391.ct529 at york.ac.uk>
>>> Content-Type: text/plain;  charset="utf-8"
>>> Dear grasslings,
>>> I was not able to understand whether there was any information provided with
>>> the images, or only the images.
>>> Best,
>> I have this dreadful feeling I'm going to expose my essential thickness
>> here but ...
>> It provides TIFFs and metadata in text files; is there an easy way to
>> use these to import directly into a suitable location, or do I have to
>> import-and-rectify?
>> Richard C
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
