[GRASS-user] slope along defined section (e.g. road, stream,)
Frank Broniewski liste at geo-dienstleistung.de
Thu Feb 7 02:11:05 EST 2008
On Wednesday 06 February 2008 18:22:12 Tim Michelsen wrote:
> 3) add the slope to the attribute table of the stream/road vector
I see the biggest problem in this part of your idea, since a spacially
extended feature (road or river in your case) simply cannot have one slope
value for its complete spatial course. More like the slope will change for
each cell of your slope raster map. So given your road is a vector you could
only apply one value for each section from node to node of your vector. Which
value should be taken or is a average value enough?
Why don't you just calculate a slope map for your required region and use
d.profile to see your slope values as a profile. Or you could use v.report to
see whats under your stream or road.
 Just a few thoughts
Greetings Frank
