[GRASS-user] bug in v.db.renamecol
Dr. Manuel Seeger seeger at uni-trier.de
Thu Feb 7 10:47:00 EST 2008
Hello all,
I found a small bug in v.db.renamecol
working on dbf- database driver, renaming a column, if (like I made) you
try to use a column name greater than 10 characters length, then it
gives an error warning, and creates a column with the new name (cut at
the end to fit 10 char), but does not fill in the column values, and(!)
deletes the old column.
This is: column data is lost!
Cheers
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www-neu.uni-trier.de/index.php?id=9607
