[GRASS-user] Projection of dataset does not appear to match the current location!!!
Thu Feb 14 16:18:34 EST 2008
Kunal Malik wrote:
>  i am Trying to display  one raster image  kept on my harddisk,,
> I have kept spearfish60 on /usr/local/grassdata so I set Location :
> spearfish60
> I have made one user user1 then i set Mapset: user1..
> then i start grass ,,
> the n throu command
> r.in.gdal -e in=nf42.tif out=tm
> then i am getting the error,.,,
> I have tried the same thru GIS manager,,,
> file->import->Raster->multiple formats using gdal..
> I want to know where i am doing wrong..
You need to create a location whose projection matches the data you
wish to import.
Try using g.proj with the -c flag and the location= and georef=
options to create a new location based upon the projection information
in the file.
You should then be able to import the file into that location with
r.in.gdal. If desired, you can then re-project it to another location
with r.proj.
