[GRASS-user] Re: grass-user Digest, Vol 22, Issue 35
Roy Sanderson r.a.sanderson at newcastle.ac.uk
Fri Feb 15 02:41:15 EST 2008
Dear Michael
That's great - I wasn't aware of these two sites which are both really
helpful and I'll follow them through.  The issue on GRASS's
scriptability is something of a double-edged sword in that it makes it
much simpler to develop models in various languages and call them inside
the script, but then there often seems to be a performance hit in terms
of CPU or file IO.  The permutation testing that goes with the
sensitivity analysis of many ABMs probably accentuates this issue.
Perhaps linkage through the new GRASS Extension Manager might speed up
processing a little, but I suspect it's more a case of revisiting some
of my coding, to make it a little less clumsy!  Judging by the number of
pdfs on agent-based models on your site, I've a lot of reading to catch
up on.
What's the relationship between the openabm list and the grass-abm one
hosted at osgeo which I've just stumbled across?  The activity on the
latter does, unfortunately, seem fairly low.
Best wishes
Roy
On Thu, 2008-02-14 at 11:20 -0500, grass-user-request at lists.osgeo.org
wrote:
> Message: 5
> Date: Thu, 14 Feb 2008 08:16:51 -0700
> From: Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS-user] Agent-based modelling and GRASS
> To: grass-user at lists.osgeo.org
> Message-ID: <1DE57E75-DADB-4807-AC00-1C7C004E9B54 at asu.edu>
> Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
> On Feb 14, 2008, at 2:53 AM, grass-user-request at lists.osgeo.org wrote:
> > Date: Thu, 14 Feb 2008 09:38:54 +0000
> > From: Roy Sanderson <r.a.sanderson at newcastle.ac.uk>
> > Subject: [GRASS-user] Agent-based modelling and GRASS
> > Message-ID: <1202981934.28165.239.camel at clarinet>
> > Hello
> > Does anyone know the current state of play with agent-based modelling
> > and GRASS?  About four years ago there seemed to be considerable
> > activity on this front, with for example, Jim Westervelt's work on
> > integrating Swarm models into GRASS for cowbird predictions (described
> > in R. Gimblett's text on GIS and ABM).  A couple of years ago I
> > developed a simple discrete-event model of bumblebee foraging,
> > using C++
> > and GRASS shell scripts, although I will admit that as communication
> > between the model and the GIS was primarily via text files that the
> > disk
> > I/O activity caused huge processing time problems.
> > Then there has been the approach of using R within GRASS, and given
> > that
> > R has its own library for individual-based ecological models (via the
> > simecol library) this may provide a more productive route for
> > developing
> > agent-based models operating within a GIS environment.  However, I
> > have
> > the impression that the technology is going through some flux, and
> > wonder what users consider to be the best approach?
> > Best wishes
> > Roy
> > Roy Sanderson
> > Institute for Research on Environment and Sustainability (IRES)
> > Devonshire Building
> > Newcastle University
> > Newcastle upon Tyne NE1 7RU
> > 0191 246 4835
> Roy,
> One of my research projects is coupling a Java-based ABM (DEVSJAVA)
> with GRASS quite successfully. Rather than trying to write an ABM in
> GRASS, we are using GRASS' scriptability to call it as needed by the
> ABM. The ABM manages the agents and their behavior; GRASS manages the
> landscape and surface process dynamics. Here is a link to our website
> <http://medland.asu.edu>. I'm happy to talk more with you on or off
> list. Also, you might want to take a look at the new OpenABM
> Consortium site <http://www.openabm.org>. If there is sufficient
> interest, I'd be happy to start a forum on ABM and GIS/GRASS there.
> Michael
> ____________________
> C. Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
