[GRASS-user] Installing R under cygwin
G. Allegri giohappy at gmail.com
Wed Feb 20 08:10:44 EST 2008
Hi Jan,
Why do you want R under Cygwin? You simply need R to be installed
under Windows. Cygwin shell "talks" with R windows version.
 - So, first install R under Windows.
 - Run Cygwin, run grass. It will open an XWindow, but don't use it.
Go back to your cygwin window and run R. It will invoke R installed on Windows.
 - So, if you have spgrass6 installed on your Windows R version, you
can load it from     cygwin, with "library(spgrass6)", and you're
ready to interface with Grass.
To try if it runs well, type gmeta6(). It will print the metadata
infos about Grass (region, mapset, etc.)
Giovanni
2008/2/20, Jan Pacina <packy at kma.zcu.cz>:
> Hello to all,
> I am trying to install the R environment to grass6.2 running under
> cygwin. I have downloaded the spgrass6 package from
> http://cran.r-project.org/web/packages/spgrass6/index.html but I do not
> have a clue what to do with it next.
> Can pls anyone help with some good instruction what to do??
> Thanks in forward.
> Jan
>   Ing. Jan Pacina                    e-mail: packy at kma.zcu.cz
>   University of West Bohemia         phone:  (+420) 37763-2692
>   Department of Mathematics          fax:    (+420) 37763-2602
>   Plzen, Czech Republic              address: Univerzitni 20, 306 14
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
