[GRASS-user] Projection of dataset does not appear to match the current location!!!
Kunal Malik kunal.malik81 at gmail.com
Thu Feb 21 00:58:22 EST 2008
Hi!
Thanks for ur support.
As u have said ,i got the georefercing information using gdalinfo.
It give following output
Driver: GTiff/GeoTIFF
Size is 5177, 3450
Coordinate System is:
GEOGCS[" Unable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value
Ellipsoid = Modified Everest Datum = Modified Everest",
    DATUM["unknown",
        SPHEROID["unnamed",6377304.063,300.8017000971244]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
Origin = (65.999420352116971,24.000579647883026)
Pixel Size = (0.001159295766052,-0.001159295766052)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=ERDAS IMAGINE
  TIFFTAG_XRESOLUTION=1
  TIFFTAG_YRESOLUTION=1
  TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  65.9994204,  24.0005796) ( 65d59'57.91"E, 24d 0'2.09"N)
Lower Left  (  65.9994204,  20.0010093) ( 65d59'57.91"E, 20d 0'3.63"N)
Upper Right (  72.0010945,  24.0005796) ( 72d 0'3.94"E, 24d 0'2.09"N)
Lower Right (  72.0010945,  20.0010093) ( 72d 0'3.94"E, 20d 0'3.63"N)
Center      (  69.0002574,  22.0007945) ( 69d 0'0.93"E, 22d 0'2.86"N)
Band 1 Block=64x64 Type=Byte, ColorInterp=Red
  Metadata:
    LAYER_TYPE=athematic
Band 2 Block=64x64 Type=Byte, ColorInterp=Green
  Metadata:
Band 3 Block=64x64 Type=Byte, ColorInterp=Blue
  Metadata:
and then i tried to import the tif file .
r.in.gdal -e in=nf42_geo.tif out=tm
WARNING: Datum 'unknown' not recognised by GRASS and no parameters found.
         Datum transformation will not be possible using this projection
         information.
 Projection of input dataset and current location appear to match.
Proceeding with import...
 100%
CREATING SUPPORT FILES FOR tm.red
SETTING GREY COLOR TABLE FOR tm.red (8bit, full range)
 100%
CREATING SUPPORT FILES FOR tm.green
SETTING GREY COLOR TABLE FOR tm.green (8bit, full range)
 100%
CREATING SUPPORT FILES FOR tm.blue
SETTING GREY COLOR TABLE FOR tm.blue (8bit, full range)
 r.in.gdal complete.
now i am trying to display the imported file..
i got the error
 g.region rast=tm
ERROR: raster map <tm> not found.
Please tell how could i display it.
Thanks in Advance
On 2/20/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> Kunal Malik wrote:
> > If i don't know the Projection Information of the File to be
> Imported,could
> > i import the raster/vector file available..
> The "Projection of dataset does not appear to match the current
> location" error can only occur if the file is georeferenced. If it
> isn't, r.in.gdal will just assume that it matches the projection of
> the current location.
> As Frank mentions, you can use gdalinfo to obtain the georeferencing
> information.
> And you can use "r.in.gdal location=" or "g.proj -c location=" to
> create a new location with the correct projection based upon what's in
> the file.
> If a file isn't georeferenced and you don't have that information
> available, you can import the file into an location with an X/Y
> projection, although you will lose the ability to perform operations
> which require projection information (e.g. reprojection).
> More generally, if you have some data but don't know what part of the
> planet that data refers to, you don't really have any data. It's like
> knowing that the answer is 42 without knowing what the question is.
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080221/86942890/attachment-0001.html
