[GRASS-user] wxpython gui: d.vect.thematic raises error
Martin Landa landa.martin at gmail.com
Mon Feb 25 12:03:12 EST 2008
2008/2/25, G. Allegri <giohappy at gmail.com>:
> Martin, I've already compiled vdigit correctly. It didn't give any
>  error or warning...
If you run 'make' in gui/wxpython/vdigit, you get two files
'grass6_wxvdigit.py' and '_grass6_wxvdigit.so'. Maybe you need to run
'make install' (depends on your installation procedure) or just copy
these file to $GISBASE/etc/wxpython/vdigit manually.
Martin
>  2008/2/25, Martin Landa <landa.martin at gmail.com>:
> > Hi,
>  >  [snip]
>  >  >  FIRST ERROR: vdigit
>  >  >  I've loaded (inside the manager) a polygon layer and an empty line
>  >  >  layer to digitize the latter.
>  >  >  Then I've run vdigit from the "tools" menu. I've selected the line
>  >  >  layer as the layer to be digitized.
>  >  >  I get an error window with:
>  >  >  "Unable to initialize display driver, see README file for more information."
>  > To make digitizer you need to compile C++ code in gui/wxpython/vdigit,
>  >  see gui/wxpython/README for detailed information.
>  >  [snip]
>  >  Martin
>  >  Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
