[GRASS-user] problem regarding the display of map
Jachym Cepicky jachym.cepicky at gmail.com
Tue Feb 26 07:03:12 EST 2008
Kunal Malik píše v Út 26. 02. 2008 v 16:56 +0530:
> HI!
> i convert the raster map to vector map and the name of new vect map is
> map_tf_v
> but when i use the display command i am getting following error
> g.region vect=map_tf_v
> ERROR: Cannot open old vector map_tf_v at PERMANENT on level 2
>  d.vect map=tgr_shp
> The bounding box of the map is outside the current region, nothing
> drawn.
> how can i display the map...???
> Thanks & Regards
could you post the commands, you used, for graster->vector conversion?
What is your platform? What is your GRASS version?
jachym
P.S. Are you sure, you want to send this message to mapserver-users as
well?
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080226/3025408b/attachment.bin
