[GRASS-user] MAPSET PERMANENT - permission denied
Kunal Malik kunal.malik81 at gmail.com
Wed Feb 27 06:45:51 EST 2008
Hi jachym,
do i need subversion tool for downloading the source code .???
OR
i have taken grass-6.2.3.tar.gz.
Does it will do the same that u mentioned in the previous mail?
But it does not have grass_trunk directory ..but it has the raster dir in
it..
could i do the same things on grass-6.2.3 and adding r.example to raster
directory,
when i tried this & run grass ..where could i see the effect of
r.exampleadded..??
it is taken from
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster/r.example
On 2/27/08, Kunal Malik <kunal.malik81 at gmail.com> wrote:
> Hi jachym,
> OR
> i have taken grass-6.2.3.tar.gz. is it will do the same that u mentioned
> it..
> directory,
> On 2/27/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> > so,
> > since I do not understand, what you are doing, I'll try to describe the
> > "development procedure" from the beginning:
> > 1) download the source code
> > 2) go to grass_trunk directory
> > 3) download r.example and unpack to grass_trunk/raster directory
> > 4) ./configure ... ; make; sudo make install
> > 5) go to grass_trunk/raster/r.example directory
> > 6) You'll have to adjust MODULE_TOPDIR variable in Makefile to "../.."
> > 7) run make
> > 8) go to grass_trunk
> > 9) run sudo make install
> > 10) start grass
> > 11) r.example should be there (r.example --help is your friend)
> > BTW: Maybe we should move [rv].example from intevation server to osgeo
> > as well ?
> > Where to store it? grass_source/grass-examples ?
> > Jachym
> > Kunal Malik píše v St 27. 02. 2008 v 10:51 +0530:
> > > Hi!!
> > > I have set the Enviroment Variable by eval 'g.gisenv'
> > > when i make echo $LOCATION_NAME it gives Map1
> > >                      echo $MAPSET GIVES kunal
> > >                      echo $GISDBASE =/usr/local/grassdata
> > > i have following queries
> > > 1.
> > >  i have copied the r.example dir into
> > > the /usr/local/grass-6.2.3/raster/ and add the r.example in the Make
> > > file present in this directory...when i make the directory it still
> > > giving the message
> > > ERROR: MAPSET PERMANENT - permission denied
> > > why is it so when i am using kunal as a mapset.
> > > 2.
> > > i want to see the output of r.example which i added ..
> > > i will run  make install after make..my grass is also running ..where
> > > to go to check the output.
> > > Please suggest the way to handle the two problems.
> > > Thanks
> > >         Thanks Glynn for your support.
> > >         On 2/26/08, Glynn Clements <glynn at gclements.plus.com> wrote:
> > >                 Jachym Cepicky wrote:
> > >                 > sorry,
> > >                 > $GRASSDATA should be the directory, where your GRASS
> > >                 data are located
> > >                 > $LOCATION_NAME should be name of the location, you
> > >                 are using  for
> > >                 > current GRASS session
> > >                 FWIW, the name of the GRASS variable for the database
> > >                 directory is
> > >                 GISDBASE.
> > >                 You can make the GRASS variables appear as shell
> > >                 variable with the
> > >                 command:
> > >                         eval `g.gisenv`
> > >                 After which, you can use the variables like e.g.:
> > >                         ls -l $GISDBASE/$LOCATION_NAME
> > >                 or:
> > >                         ls -l $GISDBASE/$LOCATION_NAME/$MAPSET
> > >                 etc.
> > >                 As for the error message in the subject: you must own
> > >                 the mapset
> > >                 directory in order to select it as the current mapset.
> > >                 The PERMANENT
> > >                 mapset will normally be owned by whoever originally
> > >                 created the
> > >                 location.
> > >                 You shouldn't use the PERMANENT mapset as the current
> > >                 mapset for daily
> > >                 use; create a new mapset instead. PERMANENT should be
> > >                 reserved for
> > >                 important data which should be readily available
> > >                 regardless of the
> > >                 current mapset.
> > >                 Until you get to the point of needing several mapsets
> > >                 in one location,
> > >                 you probably shouldn't have anything in the PERMANENT
> > >                 mapset except
> > >                 for the standard files (DEFAULT_WIND, PROJ_INFO,
> > >                 PROJ_UNITS).
> > >         Thanks & Regards
> > >         Kunal Malik
> > >         09871147561
> > > Thanks & Regards
> > > Kunal Malik
> > > 09871147561
> > Jachym Cepicky
> > e-mail: jachym.cepicky gmail com
> > URL: http://les-ejk.cz
> > GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> Thanks & Regards
> Kunal Malik
> 09871147561
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080227/be61088a/attachment.html
