[GRASS-user] How to find out an angle between to points on the map (for r.plane, r.lake)
Hamish hamish_b at yahoo.com
Thu Feb 28 22:26:47 EST 2008
Dylan Beaudette wrote:
> > Well of course I had to go and try this out.
> > attached is a patch (against todays SVN) to optionally print the
> > bearing between clicks.
you should add a check so that it won't allow bogus results if the
location is in Lat/Lon:
e.g. from d.grid:
if (geogrid->answer && G_projection() == PROJECTION_LL)
  G_fatal_error(_(".. option is not available for LL projection"));
(the great circle line's bearing changes with distance along it; unless
you are interested in the rhumbline?)
for this stuff also checkout m.cogo, r.transect, r.profile,
d.rhumbline, d.geodesic
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
