[GRASS-user] gdal-grass
gary lists at lazygranch.com
Tue Jan 1 16:50:05 EST 2008
Well, different errors. I assume you wanted that file in the gdal-grass
directory as created by tar, which in my case is
/usr/local/src/gdal-grass/gdal-grass-1.4.3
I "sourced" the file. Error message is
--with-grass=/root/grass63/dist.x86_64-unknown-linux-gnu
Markus Neteler wrote:
> Gary,
> since I am a lazy person, I have made this a script:
> http://mpa.itc.it/markus/useful/conf_install_gdal_ogr_grass_plugin.sh
> this may help you. It compiles and installs the plugin right away from
> the GDAL source code, you don't even have to download the
> separate plugin code (which is really just taken from the GDAL
> source code).
> Maybe that helps,
> Markus
> On Jan 1, 2008 9:49 PM, gary <lists at lazygranch.com> wrote:
>> I have tried pointing to where:
>> 1) the tarball was extracted
>> 2) the directory lib, contained in the directory where the tarball was
>> extracted
>> 3) a directory called grass-6.2.3, which was created in /usr/local
>> 4) the directory lib in the above directory
>> That is:
>> 1) /usr/local/src/grass/grass-6.2.3
>> 2) /usr/local/src/grass/grass-6.2.3/lib
>> 3) /usr/local/grass-6.2.3
>> 4) /usr/local/grass-6.2.3/lib
>> The error message is
>> configuration error --with-grass= blah blah blah libraries not found
>> Maciej Sieczka wrote:
>>> gary wrote:
>>>> Is this supposed to point to where I extract the grass tarball?
>>> Yes. Eg. --with-grass=/usr/local/grass-6.3.svn
>>> Maciek
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
