[GRASS-user] v.in.ogr fails on dbf with long column names
Patton, Eric epatton at nrcan.gc.ca
Fri Jan 11 08:54:44 EST 2008
>there are already several bug reports about problems (bad experiences) with the
>10 characters limit in dbf. A simple solution is to use sqlite instead.
>Regards,
> Otto
And even if you aren't an sqlite guru, you just have to install it on your system and use the
gui-based sqlitebrowser, which provides a handy interface to the most commonly-used database
functionality:
http://sqlitebrowser.sourceforge.net/index.html
~ Eric.
