[GRASS-user] problems with v.edit - merge
G. Allegri
giohappy at gmail.com
Fri Jan 11 20:02:52 EST 2008
Ok I found out the problem meanwhile you were answering. I had 4 lines but
three of them where very weird: 2 points, vertex to the same vertex -> a
point, but stored as a line. I couldn't see it, beacuse it was superimposed
on the major, single line.
I think it was a problem with the original shapefile...
Thanks anyway Martin.
2008/1/12, Martin Landa <landa.martin at gmail.com>:
> Ciao,
> 2008/1/12, G. Allegri <giohappy at gmail.com>:
> > I can't figure out how to solve a problem with a line feature shapefile
> I
> > have. It has been wrongly created as 81 single lines touching each other
> > with their vertexes. I need to merge the lines into a unique line. I've
> > tried with v.edit and the merge tool, two times. First time it gave me
> 32
> > lines, the second I receive the following result:
> > 1 of 4 features selected from vector map <costa at PERMANENT>
> > Only 1 lines found, at least two needed
> [snip]
> > I can't understand what it means: it says it selected 4 lines but then
> just
> > 1 line has been found. the post build report lists 4 lines... I'm a bit
> > confused.
> it means that your vector map contains 4 features (in this case
> lines), but you selected only one line for merging (you have to select
> at least two lines to enable merging tool).
> which parameters you used for v.edit?
> Martin
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080112/bc339ab1/attachment.html
