[GRASS-user] import tif and display it
doppelM at gmx.de doppelM at gmx.de
Tue Jan 15 03:35:29 EST 2008
hi hamish,
thank you for your answer.
> Look at the number of columns from r.info- the east/west region
> settings are wrong, and wrapping around the whole planet.
it is correct that the tif file is wrapping around whole the planet. i have a global map of the moon and this file covers the northern polregion of it.
> what does 'gdalinfo' say about the tif file?
Size is 109091, 9091
Coordinate System is:
GEOGCS["GCS_Moon_2000",
    DATUM["unknown",
        SPHEROID["unnamed",1737400,0]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
Origin = (-179.999999999999972,89.999777146508123)
Pixel Size = (0.003300000000000,-0.003300000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-180.0000000,  89.9997771) (180d 0'0.00"W, 89d59'59.20"N)
Lower Left  (-180.0000000,  59.9994771) (180d 0'0.00"W, 59d59'58.12"N)
Upper Right ( 180.0003000,  89.9997771) (180d 0'1.08"E, 89d59'59.20"N)
Lower Right ( 180.0003000,  59.9994771) (180d 0'1.08"E, 59d59'58.12"N)
Center      (   0.0001500,  74.9996271) (  0d 0'0.54"E, 74d59'58.66"N)
Band 1 Block=109091x1 Type=Byte, ColorInterp=Gray
  NoData Value=0
i hope these informations can help you so that you can help me ;)
thanks
-------- Original-Nachricht --------
> Datum: Mon, 14 Jan 2008 19:30:44 -0800 (PST)
> Von: Hamish <hamish_b at yahoo.com>
> An: doppelM at gmx.de, grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] import tif and display it
> doppelM wrote:
> > i have imported some tif files with r.in.gdal and displayed them in a
> > monitor. but one large tif file can't be displayed.
> > r.info said that:
> > Type of Map:  raster		   Number of Categories: 255
> > Data Type:    CELL
> > Rows:	      9091
> > Columns:      109091
> > Total Cells:  991746281
> >      Projection: Latitude-Longitude (zone 0)
> > 	 N: 89:59:59.197727N	S: 59:59:58.117727N   Res: 0:00:11.88
> > 	 E: 179:59:58.92W    W:       180W   Res: 0:00:00.00001
> > Range of data:    min = 1  max = 255
> > Data Description:
> >  generated by r.in.gdal
> > the other importet tif files have 9091 rows & 9091 colums and are
> > displayed correctly!
> > i set with g.region the region of the file with the information from
> > r.info but it doesn't help - nothing is displayed
> > can anybody explain me because this file can't be displayed? is there
> > a border of the filesize? i have absolutly no idea
> Hamish
> ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.
> http://tools.search.yahoo.com/newsearch/category.php?category=shopping
