[GRASS-user] Can't dissolve based on column?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Jan 16 14:41:37 EST 2008
Well... I suspected it had to do with the field type of the column
"CODE_00".
Indeed... the column was "TEXT".
After Daniels (Victoria) indications for a similar problem a change to
"integer" (using sqlitebrowser) solved the problem.
I suggest a clarification about that in the man page of v.dissolved.
Greets...
P.S. Thank you Daniel
On Wed, 2008-01-16 at 16:52 +0100,
nikos.alexandris at felis.uni-freiburg.de wrote:
> All I try to do is a dissolve... and for:
> > v.dissolve input=clc00_clean output=clc00_dissolved
> col=CODE_00
> I get:
> DBMI-SQLite driver error:
> Cannot step:
> SQL logic error or missing database
> ERROR: Cannot fetch data
> ERROR: Unable to open vector map
> <clc00_dissolved_19941 at nik> on topology
>        level 2
> ERROR: Vector map <clc00_dissolved> not found in current
> mapset
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080116/41d9ccf5/attachment.bin
