[GRASS-user] error in gis.m georectify tool
Raffaele Morelli
raffaele.morelli at gmail.com
Thu Jan 17 06:24:24 EST 2008
I have experienced this two months ago.
http://lists.osgeo.org/pipermail/grass-user/2007-October/041633.html
Now it should be fixed in 6.3cvs
regards
raffaele
2008/1/17, Leonardo Lami <lami at faunalia.it>:
> Hi Markus,
> I'm trying to use the new georectify tool in GRASS 6.3 but I have a
> little problem.
> I create my imagery group (new) with the four satellite images of
> imagery60 dataset (spot.comp, spot.ms1, spot.ms.2 and spot.ms.3).
> Then I open a mapset in spearfish60 and I set my region on "roads"
> vector extension.
> Then I Select /*Georectify*/ from the /*File*/ menu and I select the
> location/mapset (imagery60/PERMANENT) of the map to georectify
> (spot.comp), the /image group/ (new) of the map to georectify, and a map
> to use for marking GCPs (roads).
> When I click on "Start georectifying" this does'nt open the special map
> display and I have this error message:
> missing "
> missing "
> while compiling
> "Gm::errmsg $error ["Error setting region]
> ("if" then script line 2)
> while compiling
> "if {[catch {close $input} error]} {
> ("if" then script line 10)
> while compiling
> "if {![catch {open [concat "|g.region" "-up" $args "2> $devnull"] r}
> input]} {
> while {[gets $input line] >= 0} {
> set key [string trim [linde..."
> (compiling body of proc "GRMap::zoom_gregion", line 11)
> invoked from within
> (procedure "GRMap::refmap" line 51)
> invoked from within
> "GRMap::refmap"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .grstart.mf.frame.start.a"
> (command bound to event)
> Any idea about this?
> Thank you
> Regards
> leonardo
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080117/b318ca71/attachment.html
