[GRASS-user] Vector drawings in PDF -> converting them
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Jan 17 09:58:36 EST 2008
On Wednesday 16 January 2008 11:22:02 pm Kurt Heston wrote:
> I have a TON of vector drawings available to me in PDF format that I'm
> georeferencing. So far, I'm doing it by converting them to PNGs and
> using r.to.vect to massage them. This is really tedious and the data
> isn't as clean as a straight vector conversion would be. In
> Illustrator, I can see that all the vector math is there. That is, the
> PDF isn't simply a wrapper around raster data.
> I've tried opening the PDFs in Illustrator and exporting them as DXFs,
> but Grass ignores a lot of the data when I do this...they look very
> different in Grass once imported. I can export them as SVG from
> Illustrator, but surprisingly, there doesn't appear to be a single
> open-source tool available out there that converts SVG into some
> mainstream GIS file format.
> Does anyone have experience doing this type of conversion? Pointers
> welcome.
Check out Inkscape.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
