[GRASS-user] i.landsat.rgb problem
Philipp Steigenberger userlist at online.de
Thu Jan 17 10:39:07 EST 2008
>Hi all,
>i tried i.landsat.rgb on GRASS 6.3 but I have this error message and the
>color tables of the three raster are setted with all values white.
>I obtained this three brov raster from i.fusion.brovey applied on
>Landsat images.
>i.landsat.rgb -p red=brov.red at PERMANENT green=brov.green at PERMANENT
>blue=brov.blue at PERMANENT strength=90
>Processing [brov.red at PERMANENT] ..
>/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 36.9801: integer
>expression expected
>/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.7707: integer
>expression expected
>Processing [brov.green at PERMANENT] ..
>/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 39.6825: integer
>expression expected
>/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.1483: integer
>expression expected
>Processing [brov.blue at PERMANENT] ..
>/usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 24.107: integer
>expression expected
>/usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 13.1111: integer
>expression expected
>Color table for <brov.red at PERMANENT> set to rules
>Color table for <brov.green at PERMANENT> set to rules
>Color table for <brov.blue at PERMANENT> set to rules
>Thank you
>Leonardo
>_______________________________________________
>grass-user mailing list
>grass-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/grass-user
Hi
have a similar problem with
"i.fusion.brovey -l ms1=20 ms2=40 ms3=50 pan=80 outputprefix=ls7 --o"
the output maps I get are gray. Three different grays, but not like it should look like.
I'm not admin on my system so I have no idea if the script (*.diff) from Martin is working in my case too.
Same problem in another color? ;o)
Thank you
om shantih
Philipp
