[GRASS-user] problems starting wxPython gui using wingrass
Martin Landa landa.martin at gmail.com
Thu Jan 17 12:49:05 EST 2008
related to wxpython
make -C vdigit || echo /usr/local/src/grass_trunk/gui/wxpython/vdigit >> /usr/lo
cal/src/grass_trunk/error.log
make[1]: Entering directory `/usr/local/src/grass_trunk/gui/wxpython/vdigit'
Makefile:27: warning: overriding commands for target `clean'
../../../include/Make/Rules.make:72: warning: ignoring old commands for target `
clean'
swig -c++ -python -shadow grass6_wxvdigit.i
make[1]: swig: Command not found
make[1]: *** [grass6_wxvdigit_wrap.cxx] Error 127
make[1]: Leaving directory `/usr/local/src/grass_trunk/gui/wxpython/vdigit'
1) swig is missing (just read the error output...)
2) please take a look also at README (gui/wxpython/README)
3) the code in gui/wxpython/vdigit is needed only for experimental
digitization tool, the rest of GUI will work even if this fails...
Martin
2008/1/17, nikos.alexandris at felis.uni-freiburg.de
<nikos.alexandris at felis.uni-freiburg.de>:
> wxgrass doesn't work.
> Error's after "make" below.
> Following modules are missing the 'description.html' file
> in src code:
> GRASS GIS compilation log
> Started compilation: Thu Jan 17 16:20:58 CET 2008
> Errors in:
> /usr/local/src/grass_trunk/lib/ogsf
> /usr/local/src/grass_trunk/visualization/nviz
> On Thu, 17 Jan 2008 08:15:40 -0700
>  Michael Barton <michael.barton at asu.edu> wrote:
> > I'm glad that you're finally getting the correct code.
> > I'm confused  about it's availability too. Please let us
> > know how it runs once you  can get it and test it.
> > Michael
> > ____________________
> > C. Michael Barton, Professor of Anthropology
> > Director of Graduate Studies
> > School of Human Evolution & Social Change
> > Center for Social Dynamics & Complexity
> > Arizona State University
> > Phone: 480-965-6262
> > Fax: 480-965-7671
> > www: <www.public.asu.edu/~cmbarton>
> > On Jan 17, 2008, at 4:54 AM,
> > nikos.alexandris at felis.uni-freiburg.de  wrote:
> > > Thank you for the clarification (again).
> > > (1) ??? I can put my hand on fire (greek... or
> > universal
> > > expression) that I was getting an error with "svn up"
> > but
> > > now not!
> > > (2) Yes... trunk... (sorry for insisting).
> > > On Thu, 17 Jan 2008 10:28:41 +0100
> > >  "Martin Landa" <landa.martin at gmail.com> wrote:
> > >> Hi,
> > >> 2008/1/16, Nikos Alexandris
> > >>> I am sorry for bothering again.
> > >>> I am on ubuntu.
> > >>> I updated (sudo svn up) from within
> > >> general note, why are you running 'svn up' as sudo??
> > >>> the /usr/local/src/MyGRASSsourceDirectory
> > >>> Configured-compilled-installed.
> > >>> No wxgrass anywhere.. only a few irrelevant scripts
> > >> under... :
> > >>> GRASS 6.3.0RC4
> > >> (Peloponnese_HGRS87):/usr/local/grass-6.3.0RC4/etc/gui
> > >>> ls
> > >>> icons  scripts
> > >>> So... I go in /usr/loca/src/MyGRASSsrcDir/gui
> > >>> directory and I only find "wxpython" as a folder
> > which
> > >> does not contain
> > >>> any "wxgrass" script.
> > >>> GRASS 6.3.0RC4
> (Peloponnese_HGRS87):/usr/local/src/release_20080109_grass_6_3_0RC4/
> > > gui/wxpython
> > >>> ls
> > >>> archive  gm.wxp       grass-interface.dtd  mapdisp.py
> > >>  scripts
> > >>> gism.py  grassgui.py  Makefile             render.py
> > >> Once more, in grass 6.3 is old wxpython code. Use
> > >> svn-trunk instead.
> > >> svn checkout https://svn.osgeo.org/grass/grass/trunk
> > >> grass_trunk
> > >> Martin
> > >> Martin Landa <landa.martin at gmail.com> *
> > >> http://gama.fsv.cvut.cz/~landa *
>          Nikos Alexandris - Ph.D. Candidate
>             Department of Remote Sensing
>                        and
>             Landscape Information Systems
>                      (FeLIS)
>       Faculty of Forestry and Natural Environment
>           Albert-Ludwigs-University Freiburg
>             Tel.  +49 (0) 761 203 3697
>             Fax.  +49 (0) 761 203 3701
>              Skype: Nikos.Alexandris
>            Address: Tennenbacher str. 4
>               D-79106 Freiburg i. Br.
>                      Germany
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
