[GRASS-user] i.rectify - how long is too long
Moritz Lennert mlennert at club.worldonline.be
Sat Jan 19 15:32:47 EST 2008
On 19/01/08 00:25, Luis E Menoyo wrote:
> I'm using 1st order and 13 GCPs on an image and i.rectify has been
> running over 3 hours.  Is the process locking up or is this amount of
> time normal in image rectification?  Is i.rectify processing just the
> area of the image to be rectified, of is it calculating for the whole
> target mapset area?  In other words, should I have applied a mask to the
> target mapset before running the georectify tool in order to cut down on
> processing time?
What are your region settings in the target location, especially the
resolution ? This can make an enormous difference in terms of
calculation time.
Moritz
> Any info would be greatly appreciated.
> Thanks!
> Image info:
>  | Layer:    D-10 at PERMANENT                 Date: Fri Jan 18 08:17:14
> 2008    |
>  | Mapset:   PERMANENT                      Login of Creator: me        |
>  | Location: x-y
>  | DataBase: /gis/oahu_flightlines                     |
>  | Title:     ( D-10 )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 255
>  |   Data Type:    CELL
>  |   Rows:         4171
>  |   Columns:      3280
>  |   Total Cells:  13680880
>  |        Projection: x,y
>  |            N:       4171    S:          0   Res:     1
>  |            E:       3280    W:          0   Res:     1
>  |   Range of data:    min = 0  max = 255
>  |   Data Description:
>  |    generated by r.in.gdal
>  |   Comments:
>  |    r.in.gdal input="/gis/oahu_flightlines/D/D-10\   |
>  |    .jpg" output="D-10"
> Computer:
> Mac Pro 2.66GHz, 2 dualcore Intel Xeon (4 cores total), 4Gb RAM
> GRASS:
> GRASS 6.3.0RC4 (2008)
> Luis E. Menoyo
> U.S. Geological Survey
> 677 Ala Moana Blvd., Suite 415
> Honolulu, HI  96813
> lemenoyo at usgs.gov
> 808-587-2428
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
