[GRASS-user] Re: Virtual memory available to cygwin GRASS
Luigi Ponti lponti at infinito.it
Mon Jan 21 10:25:16 EST 2008
Glynn Clements wrote:
> Any process will use 100% CPU unless either it can process the data
> faster than the OS can provide it or it has to contend for the CPU
> with other active processes.
> The only time the CPU will be idle is if no process is ready to run,
> i.e. if all processes are blocked waiting for input, whether user
> input or data from a disk, network connection, external device, etc.
OK: I will take some notes!
Thanks very much for addressing this off-topic.
Kind regards,
Luigi
