[GRASS-user] MASK does not do it's work (?) with r.mapcalc -- Again!
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Jan 22 08:22:20 EST 2008
I still can't explain why I can't create a mask with the following raster:
 | Layer:    NDVI20060.35                   Date: Tue Jan 22 13:53:02 2008
 | Mapset:   nik                            Login of Creator: nik
 | DataBase: /home/nik/grassWorks/Peloponnese_DamageAssessment2007
 | Title:     ( NDVI20060.35 )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 255
 |   Data Type:    DCELL
 |   Rows:         1048
 |   Columns:      972
 |   Total Cells:  1018656
 |        Projection: Transverse Mercator
 |            N:    4255830    S:    3993750   Res: 250.07633588
 |            E:     468810    W:     225720   Res: 250.09259259
 |   Range of data:    min = 0.001304  max = 0.349991
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    if((NDVI2006 > 0 && NDVI2006 < 0.350000), NDVI2006, null())
Whenever I "r.mask input=NDVI20060.35" or with "rmapcalc MASK=NDVI20060.35",
I get nothing when I try to view or to use r.mapcalc on others rasters.
Any ideas about this?
Thank you,
Nikos
View this message in context: http://www.nabble.com/MASK-does-not-do-it%27s-work-%28-%29-with-r.mapcalc-tp14407246p15018501.html
Sent from the Grass - Users mailing list archive at Nabble.com.
