[GRASS-user] i.rectify - how long is too long
Luis E Menoyo
lemenoyo at usgs.gov
Wed Jan 23 13:01:06 EST 2008
I started using the display to set the target region and g.region to set
the resolution. I also run the georeferencing rutine at low resolution
first to more accuratly determine the target area and then run at higher
resolution for the final product. The whole process (setting GCPs and
running at different resolutions) takes about an hour per aerial photo,
which is acceptable. The quality of the final image is very close to that
of the source image.
Thanks to everyone for their help.
Luis E. Menoyo
U.S. Geological Survey
677 Ala Moana Blvd., Suite 415
Honolulu, HI 96813
808-587-2428
Hamish <hamish_b at yahoo.com>
01/22/08 03:14 PM
To
Luis E Menoyo <lemenoyo at usgs.gov>, grass-user at lists.osgeo.org
cc
Subject
Re: [GRASS-user] i.rectify - how long is too long
Luis E Menoyo wrote:
> It looks like i.rectify processes the complete target area instead of
> just the image area to be rectified.
tip: use v.in.region + v.proj to set up target region / resolution
prior to using r.proj or i.rectify.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080123/7a1b0a23/attachment.html
