[GRASS-user] clip and rotate a raster
Sat Jan 26 00:45:04 EST 2008
G. Allegri wrote:
> Surely a stupid question, but I can't find a way to clip a raster on the
> base of the region settings and/or the base of a vector. I can MASK, I can
> reclass, but I can't clip!
r.resample will resample a map according to the current region
settings.
To clip to a vector map, convert the vector area(s) to a raster then
use it as a mask.
> Furthermore, is it possible to rotate a raster without the use of a 1st
> polynomial rectification through GCPs?
No.
You can translate and/or scale a map by changing its boundaries with
r.region, but the only tool to rotate or skew a map is i.rectify
(there isn't an r.rectify).
