[GRASS-user] v.extract how to extract points one by one following their FID number
Patrick Giraudoux patrick.giraudoux at univ-fcomte.fr
Sun Jan 27 12:33:37 EST 2008
Dear all,
Now, I am very happy  with a programme running (this is my first real
programme in GRASS with a GUI, etc) that can sweep multiple radius
buffers over points selected one by one from a point vector map and
save  the pixel count of each category of the overlapping raster in  a
text file. However, the point selection process is based on the category
values of the vector file. Example:
 v.extract -t in=$vector out=essaisV list=$count type=point --o --q
2>/dev/null # point extraction
where $count is incremented from 1 to the number of points.
This could be messy if two different points have the same category value
(I currently manage to get category value unique and ranging from 1 to
the number of points, so that each point is extracted alone).
I wonder if it would be possible to make it in a safer way, e.g. to
extract vectors as does v.extract but with a selection grounded on the
unique FID number of each point (and not on its category value as e.g.
with 'list=1' in v.extract). This means to read the FID numbers of a
point vector map and then to extract stepwise each vector point to a new
vector map calling it via its FID.
Any hint appreciated,
Cheers,
Patrick
