[GRASS-user] SHELL variable not set
Roberto Antolin roberto.antolin at polimi.it
Mon Jan 28 13:17:12 EST 2008
Hello Martin and all,
Martin Wegmann escribió:
> Is is a GRASS or Linux specific problem? Any idea which SHELL variable I have
> to set? And how to do so?
I'm not sure, but I think you have to set just the SHELL variable. Try
to check in this way: 'echo $SHELL'. If you get nothing then you can set
it to '/bin/bash' in the terminal you are using. If you want to set it
permanently, try this: chsh -s /bin/bash. You can use BASH or whatever
other shell you like.
I hope this helps,
Roberto.
Roberto Antolín Sánchez
Politecnico di Milano - Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 - 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
roberto.antolin en polimi.it
