[GRASS-user] Pre-processing LANDSAT TM Orthorectified images from GLCF
maning sambale emmanuel.sambale at gmail.com
Mon Jun 2 04:41:50 EDT 2008
Markus,
> AFAIK LANDSAT is sun-synchronous, it passes in the local morning time
> (something like 10:30-11:00).
> Maybe this helps:
> http://earthobservatory.nasa.gov/MissionControl/overpass.html
Since it is an overpass predictor, it doesn't provide information on
previous landsat overpass.  Can I use this as a proxy to the hh:mm for
i.atcorr (me thinks no)?  Or set an arbitrary time say between 10:30
to 11:00?
> i.atcorr is the sophisticated correction, i.landsat.dehaze only a simple
> approach based on image statistics.
>> 3. correction for topographic/terrain effects (most of my study area
>> are in maountainous regions)
>> use book 2nd ed. (page 226) "cosine correction"
>> using r.sunmask, r.mapcalc
>> Problem: again, no image acquisition time
> (see above). "cosine correction" is a simple approach. See also
> i.topo.corr (from GRASS AddOns).
Thank you for this one.
>> 4. removal of clouds
>> use i.landsat.acca
>> https://svn.osgeo.org/grass/grass-addons/imagery/i.landsat.acca/
> Never tried, please report back.
Will do, via wiki.
> I have collected all this now in
> http://grass.osgeo.org/wiki/Image_processing#Preprocessing
> Feel free to further improve that Wiki page.
> Markus
As usual, thank you very much.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
