[GRASS-user] Error in v.vol.rst
Manuel Seeger seeger at uni-trier.de
Fri Jun 6 05:40:42 EDT 2008
Hello,
I trying to generate a 3d DEM of a gully headcut. The point data was
gained by terrestrial laser scanner.
As I am doing my first attempts, I do not change any parameters from
that given by default.
This is the result:
v.vol.rst input=BAR1_SCAN_UTM at Georef41 wcolumn=dbl_3 tension=40.
smooth=0.1 segmax=50 npmin=200 dmin=0.050026 wmult=1.0 zmult=1.0
elev=Olite_3d --overwrite
1511728 records selected from table
some points outside of region -- will ignore...
strip exists with insufficient data
Processing all selected output files will require 1435616 bytes of disk
space for temp files
There are points outside specified 2D/3D region--ignored 57754 points
(total points: 1511728)
Points are more dense than specified 'DMIN'--ignored 1131669 points
(remain 380059)
Percent complete:
Error in COGRR!
Interp_call failed!
Can someone give me an idea if this is my fault?
Thank you!
Manuel
_______________________________________________________________________
Dr. Manuel Seeger
Wiss. Assistent 			Scientific Assistant
Physische Geographie 			Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften 	Geography/Geosciences
Universität Trier			University of Trier
D - 54286 Trier
Tel.:	+49-651-201 4557
Fax:	+49-651-201 3976
Web:	http://www-neu.uni-trier.de/index.php?id=9607
