[GRASS-user] area stats on a lon/lat projection
maning sambale emmanuel.sambale at gmail.com
Mon Jun 9 22:15:44 EDT 2008
Thank you for the clarification.
On Mon, Jun 9, 2008 at 4:52 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Maning Sambale wrote:
>> I know it should not be really practiced, but how accurate is the areal
>> calculations (hectares) in v.report when the projection is lon/la wgs84?
>> I have a vector data that covers several utm grids that I want to
>> compute "hectarage".
> AFAIK, the calculation is "exact", in the sense that it computes the
> integral with respect to latitude.
> The real issue is one of definition. Specifically, the polygon is
> deemed to be bounded by straight lines (in lat-lon) between the
> vertices, not geodesic lines (or straight lines in UTM). If your
> polygon edges are large, this will make a difference.
> If you want to know the precise calculation, see
> G_ellipsoid_polygon_area() in lib/gis/area_poly1.c.
> Also, bear in mind that projecting vector data (e.g. from UTM to
> lat-lon) merely projects the vertices, so you are effectively changing
> the shape of the area. In both cases (before and after projection),
> the polygon is bounded by straight lines between the vertices
> (straight lines in UTM before, straight lines in lat-lon after),
> whereas applying a non-affine projection to a straight line will not
> generally produce a straight line. I think that v.split may be of use
> here (if I understand it correctly).
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
