[GRASS-user] problem with column label using r.cross
Christian Schwartze Christian.Schwartze at uni-jena.de
Wed Jun 25 05:02:33 EDT 2008
At the moment I solve it by splitting the label data ("category 3; category 12
..") to separate database backend columns. Use such modules like v.db.addcol,
v.db.select and v.db.update to create own columns for each crossing category.
But unfortunately it takes a little bit too long...
Regards,
Christian.
Am Dienstag, den 24.06.2008, 15:32 +0200 schrieb Christian Schwartze:
Zitat von Hamish <hamish_b at yahoo.com>:
> > > Christian Schwartze
> > > Ok and thanks, better to look at first within GRASS if
> > > eveything is working fine
> > > ;) (in cats/ full category values) Because the reduced line
> > > comes from QGIS
> > > (selection tool). I forgot to say that following r.cross I
> > > do a conversion with
> > > r.to.vect and export the result to a shapefile. So the
> > > original label vals were
> > > mapped to dbf-column type "C". But why exporting only 80 chars?
> > Does v.db.select show the cut string?
> > which DB backend? (dbf?)
> v.db.select shows the full length of column label for all data rows - nothing
is
> missing. I use dbf backend.
> > "db.describe -c vect_map" ?
> ncols:3
> Column 1:cat:INTEGER
> Column 2:value:INTEGER
> Column 3:label:CHARACTER
> Christian.
> > Hamish
> This mail was sent through http://webmail.uni-jena.de
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
