[GRASS-user] installation problems in user space
Abhinandan Raghavan abhinandan.raghavan at gmail.com
Mon Jun 30 12:54:19 EDT 2008
continuing with my woes while trying to install grass, I've managed to
install gdal but when I try and compile grass, I get this message:
checking for jpeg_start_compress in -ljpeg... yes
checking whether to use GDAL... yes
yes
checking for gdal-config... no
configure: error: *** couldn't find gdal-config
the options that I've used for the compilation are:
a) --with-proj-includes
b) --with-proj-libs
c)  --with-proj-share
d) --with-gdal
I'm not sure if something is being missed out. If you are aware of anything
else that might have gone wrong, then let me know. I use --with-gdal to
point to the correct gdal-config file but I still get the message "couldn't
find gdal-config".
Abhi
On Thu, Jun 26, 2008 at 3:48 PM, Abhinandan Raghavan <
abhinandan.raghavan at gmail.com> wrote:
> Hi folks,
> Thanks a lot for getting back. I am now having trouble with installing
> gdal. This is the message that I get:
> g++: /usr/lib/libidn.so: No such file or directory
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/scratch/lib/gdal-1.5.2'
> make: *** [check-lib] Error 2
> Wonder why this has to be so complicated!
> Abhi
> On Thu, Jun 26, 2008 at 3:19 PM, Craig Leat <craig.leat at gmail.com> wrote:
>> Hi
>> On Thu, 26 Jun 2008 14:00:21 +0200,  Abhinandan Raghavan wrote:
>> > I'm having trouble with installing grass in my directory. I would like
>> to
>> > install grass locally as I don't have root privileges. I've completed
>> > installing proj4 in a local area but cannot get grass to realize that it
>> has
>> > been installed. when I run the configure script, I get the following
>> > message:
>> > configure: error: *** Unable to locate External PROJ.4 includes.
>> > any help would be appreciated :)
>> I have never tried this, but once noticed the following link with
>> details on installing GRASS locally. Maybe it helps?
>> http://www.reprojected.com/geoblog/how-tos/gis-on-a-shared-hosting-environment-the-magic-of-not-having-root/
>> Craig
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080630/fbb59249/attachment.html
