[GRASS-user] Problems to update with svn
Philipp Steigenberger userlist at online.de
Sat Mar 1 07:11:13 EST 2008
Hello
Martin Landa schrieb:
> Hi,
> 2008/3/1, Philipp Steigenberger <userlist at online.de>:
>>  I tried to update my svn GRASS version but got problems
>>  using svn up I get
>>  svn: Failed to add file 'gui/wxpython/vdigit/Makefile': object of the
>>  same name already exists
> Makefile is not gererated from Makefile.in anymore [1]. Try to remove
> Makefile from 'gui/wxpython/vdigit', run svn cleanup & svn up.
I had to remove the vdigit-directory - but it worked
>>  then running the configure with
>>  export CC=/usr/bin/gcc-3.4 #
>>  ./configure --with-freetype --with-glw  --with-gdal \
>>  --with-postgres-includes=/usr/include/postgresql \
>>  --with-freetype-includes=/usr/include/freetype2 --with-python \
>>  --with-readline --with-odbc --with-lapack --with-blas --with-cxx \
>>  --with-nls --with-mysql-includes=/usr/include/mysql \
>>  --with-tcltk-includes=/usr/include/tcl8.4
>>  #(this configure-list worked some weeks ago)
>>  checking whether to use Python... yes
>>  checking for python-config... no
>>  configure: error: *** couldn't find python-config
>>  apt-file search python-config
>>  doesn't help
> see [2]
> `apt-get install python2.4-config` or python2.5-config based on your
> Python version
I installed python2.5 but
apt-get install python2.5-config
Reading package lists... Done
Building dependency tree... Done
E: Couldn't find package python2.5-config
How to get it?
Philipp
> configure with --with-python=/path/to/python2.x-config
> Martin
> [1] http://trac.osgeo.org/grass/changeset/30173
> [2] http://trac.osgeo.org/grass/changeset/30171
