[GRASS-user] r.cost source ID question...
Hamish hamish_b at yahoo.com
Sun Mar 2 00:48:27 EST 2008
Jonathan Greenberg wrote:
> If I have a r.cost surface calculated from a set of vector points
> used as starting points, and some cost surface, is there any way to
> easily retrieve the SOURCE vector ID that leads to the lowest cost
> to get to any cell in the raster?  E.g. from a given point, where
> is the point that costs the least to get to?
It sounds a bit like an inverted topographic prominence problem.
  http://article.gmane.org/gmane.comp.gis.grass.user/19467/
As Dylan wrote, r.drain should help find the path to the nearest pit.
Other water flow modules may help too.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
