[GRASS-user] Checking if a point (X, Y) is inside the polygons of a shape file using command line
John C. Tull john.tull at wildnevada.org
Mon Mar 3 11:34:20 EST 2008
Corrado,
You can do this with v.select:
v.select ainput=input_points binput=input_polygon out=output_points
Cheers,
John
On Mar 3, 2008, at 8:02 AM, Corrado wrote:
> Dear friends,
> I have a shape file, with some polygons. (I have imported it as
> vector layer.)
> I have a point, expressed as X,Y coordinates (Easting,Northing).
> I want to know if the point is inside any of the polygons in the
> shape file.
> Is there a command I can use?
> I would rather use command line,  because I have many points,
> really.  I would
> like to find a way to do it from the command line, so that I can
> write a
> routine to extract each point and check if it is inside the polygons.
> I can rephrase the question, if it is not clear.
> I am not very experienced with Grass but would like to substitute
> ArcGIS, that
> we are using now.
> Best regards
> Corrado Topi
> Global Climate Change & Biodiversity Indicators
> Area 18,Department of Biology
> University of York, York, YO10 5YW, UK
> Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
