[GRASS-user] vector data: creating areas from polygon and contour lines?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Mon Mar 3 18:19:56 EST 2008
On Mon, 2008-03-03 at 17:16 -0600, Jaime Carrera wrote:
> Hi list,
> For a couple of days I've been trying to create three different areas
> from a polygon  (outer boundary) and two contour lines. The polygon is
> rectangle-shaped, while the contours intersect the rectangle on the
> right hand side boundary. Is there a way to create three different
> areas from these vector maps? I've tried v.path, v.overlay and v.clean
> but somehow the contour lines are not broken at the intersection with
> the rectangle so no areas are created.
> Any hints?
v.extract (?)
> Thanks!
> Jaime
Cheers,
Nikos
> ______________________________________________________________________
> ¡Capacidad ilimitada de almacenamiento en tu correo!
> No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
> http://correo.espanol.yahoo.com/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
