[GRASS-user] Using GRASS to solve the "Checking if a point (X, Y) is inside the, polygons of a shape file using command line."
Corrado ct529 at york.ac.uk
Tue Mar 4 12:10:14 EST 2008
Dear friends,
Where do I find these files, like poly.c? I cannot find them on my
installation. I have 6.2.3 on Ubuntu 7.10, with the grass-dev package
installed.
Do I have to use python?
I thought I could use a bash script.
On Tuesday 04 March 2008 16:45:47 Rick Reeves wrote:
> Hamish:
> Good point. For a large dataset such as Corrado's, it would be better to
> use GRASS,
> once Corrado surmounts the GRASS learning curve. R is a good alternative
> choice
> in that it is simpler to use.
> Regards, RR
> Hamish wrote:
> > Rick Reeves wrote:
> >> This is a good task for the R programming environment, which has
> >> strong geospatial tools and integrates with GRASS:
> > FYI, in GRASS's vector library (available outside of C with e.g.
> > SWIG-Python) there a number of x-in-polygon functions found in
> > lib/vector/Vlib/poly.c. v.buffer uses such a test to check that its
> > centroid is inside the new area, you could trace that back if you
> > wanted to see the method in use.
> > from GRASS modules there is v.select and 'v.distance dmax=0' (?) and
> > probably other ways too.
> > many roads,
> > Hamish
> > _________________________________________________________________________
> >___________ Be a better friend, newshound, and
> > know-it-all with Yahoo! Mobile.  Try it now.
> > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Best Regards
Corrado Topi
Global Climate Change and Biodiversity
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
