[GRASS-user] wxpython fails to open existing grc
Martin Landa landa.martin at gmail.com
Tue Mar 4 14:54:24 EST 2008
Hi Adam,
hm, I guess you created the grc file in gis.m. The format is
completely different in wxPython GUI, see
http://trac.osgeo.org/grass/ticket/77
File extension must be changed otherwise users will be confused.
Martin
2008/3/4, Adam Dershowitz <adershowitz at exponent.com>:
> I just upgraded from 6.3 RC 4 to 6.3 RC5 (using William Kyngesburye's
> binaries on a Mac).
> Now when I open the wxpython gui, if I try to open an existing .grc file it
> doesn't open and I get the following errors:
> Traceback (most recent call last):
>   File
> "/Applications/GRASS-6.3.app/Contents/MacOS/etc/wxpython/wxgui.py",
> line 524, in OnWorkspaceOpen
>     self.LoadGrcXmlToLayerTree(filename)
>   File
> line 569, in LoadGrcXmlToLayerTree
>     xml.sax.parseString(fileStream, grcXml)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/sax/__init__.py",
> line 49, in parseString
>     parser.parse(inpsrc)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/sax/expatreader.py",
> line 107, in parse
>     xmlreader.IncrementalParser.parse(self, source)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/sax/xmlreader.py",
> line 123, in parse
>     self.feed(buffer)
>   File
> line 211, in feed
>     self._err_handler.fatalError(exc)
>   File
> "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/xml/sax/handler.py",
> line 38, in fatalError
>     raise exception
> xml.sax._exceptions.SAXParseException: <unknown>:1:0:
> syntax error
> This didn't happen with RC4 and doesn't happen with the RC5 when using the
> tcl GUI.
> --Adam
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
