[GRASS-user] please help: v.rast.stats
Thomas Adams Thomas.Adams at noaa.gov
Wed Mar 5 04:20:34 EST 2008
Jonathan,
I've seen mention of starspan previously and now I think it's time for
me to learn more. Let me pose a problem to you to see if starspan would
be of help. I am working on a modeling project with a couple of other
people that involves the following:
(1) downloading and decoding gridded fields of numerical weather
prediction (NWP) model output
(2) ingesting the decoded data into GRASS to calculate basin average
precipitation & temperature (separate grids) for each subbasin
(3) writing out all calculated basin average values for each grid to
separate files (one file contains one time step of data for all
subbasins) for both temperature & precipitation
(4) for data management reasons, the files from (3) are written to a
PostgreSQL database
(5) once all time steps of gridded precipitation and temperature field
data are written to the PostgreSQL database, another process collects
the data and generates individual ascii time series files for each
subbasin for both temperature & precipitation
(6) once (5) is completed a hydrologic model runs using the temperature
& precipitation time series as input and hydrologic forecasts are generated.
This is suppose to be a *real-time* process. The problem I am having is
a matter of scale. What I did not say is that there are 12 different
sets of NWP output covering a period of 168 hours at 6-hour time steps
for both temperature & precipitation. So, this means I must process
12*2*(168/6) = 672 grids. Also, I need the mean areal values for 686
subbasins within the domain for each of the grids.
Steps (2-4) take about 20 seconds total for each of the grids… which is
~7.5 hours total
Step-5 also takes about 20 seconds for each time series file… which is
~7.5 hours total
So, about 15 hours total. Now, I can cut this time in half by running
the processing of the temperature & precipitation grids and generating
their separate time series files in parallel, rather than sequentially.
So, I can get to about 7 hours fairly easily — what I am shooting for is
to get the processing time from 7 hours to about 3 hours (or less).
I need to more efficiently generate the many basin average time series
files from the numerous grids. Can starspan help by reducing the time to
calculate the the basin average values faster?
I would also appreciate any/all suggestions on how to efficiently go
from 'starspan generated basin average values' to my time series files.
Realize, of course, the the individual grids are only a slice in time,
so I have to track the grids and their resulting individual basin values
(in time) to generate the time series files.
To compound the problem, very soon, I need to add model grids from an
additional 21 models, bringing the total from 12 to 33!
Regards,
Tom
Jonathan Greenberg wrote:
> Hey guys, wanted to echo this -- we are continuing development on
> starspan again -- it works with gdal 1.5, among other improvements,
> and if you have any feature requests (or if anyone can help us make
> this into a grass package :), please email me or Carlos Rueda!
> --j
> Nikos Alexandris wrote:
>> On Tue, 2008-03-04 at 17:08 -0800, Dylan Beaudette wrote:
>>> On Tuesday 04 March 2008, Nikos Alexandris wrote:
>>>> On Tue, 2008-03-04 at 12:57 +0000, christian Brandt wrote:
>>>>> Dear list,
>>> Also-- see the application 'starspan'. works with GRASS, based on
>>> GDAL and GEOS.
>> Although Jose Luis Gomez replied to a question of mine about this in the
>> past, I never really gave it a try. Now I realise it's fast and does
>> what I want ;-)
>> I am still satisfied doing my attempt to script because I learnt 2-3
>> things more.
>>> Cheers,
>>> Dylan
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
