[GRASS-user] removal of duplicate points
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Wed Mar 5 13:30:28 EST 2008
maybe a script to remove each fifth line of the ascii?
carlos
On Wed, Mar 5, 2008 at 3:27 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
>  On Wed, 2008-03-05 at 09:58 -0800, Dylan Beaudette wrote:
>  > Hi,
>  Hi Dylan
>  > I have some "squares" which are stored as polygons. When converting these to
>  > points (v.to.points) I am left with the 5 points (first and last point are
>  > duplicated) that define the corners of the "square".
>  > Is there a vector module (v.edit / v.clean) that could remove duplicate
>  > points? I would like to replace the manual operation with v.digit with
>  > something that can be scripted. Note that there are multiple "squares", so a
>  > simple v.out.ascii | head -4 | v.in.ascii  would be a little awkward.
>  > Ideas?
>  Not really a solution but maybe...
>  If polygons have first and last points duplicated what happens if they
>  are converted in polylines?
>  Duplicate coordinates still there?
>  If not it could be an easy method to convert boundaries to lines and
>  continue your task.
>  _______________________________________________
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
