[GRASS-user] Re: Update - Check points in polygons
John C. Tull john.tull at wildnevada.org
Thu Mar 6 12:19:13 EST 2008
I have not found a way to work directly with postgis tables. You can
use v.in.ogr like this:
v.in.ogr dsn="PG:dbname=your_postgis_db host=yourhost"
layer=table_from_postgis out=new_layer
You then have the postgis table available as a layer in grass, but you
will not be able to edit it directly from grass to my knowledge.
Someone else might be able to supply the v.out.ogr statement that
would update the table in postgis.
Cheers,
John
On Mar 6, 2008, at 8:57 AM, Corrado wrote:
> Dear John,
> I have used postgis to load a shapefile into the postgres database,
> by means
> of shp2pgsql.
> When I then start grass, how could I can connect to the databse, but
> I do not
> understand how to generate a vector map from the postgis table.
> Any help?
> Best Regards
> Corrado Topi
> Global Climate Change and Biodiversity
> Area 18,Department of Biology
> University of York, York, YO10 5YW, UK
> Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
