[GRASS-user] occurrence of attributes in vektortable
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Mar 7 07:12:45 EST 2008
On Fri, 2008-03-07 at 11:37 +0100, Marco Lechner wrote:
> hi list,
> how can i get a list of all different occurences in a column of an
> attributetable.
Marco,
in a linux-box another way would be to combine db.select with the "sort"
command.
Example (commands in quotes):
I have a table TrainingSamples which looks like:
"v.info -c TrainingSamples"
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|clccode_le
TEXT|label
"db.selct TrainingSamples"
1|3|vegetation
2|334|Burned
3|334|Burned
45|332|non_veg
46|2|agro
And I want to get only the number of different  labels (in column
"label")
"db.select TrainingSamples | cut -d "|" -f3 | sort -u"
agro
Burned
label
minext
non_veg
non_vegetation
urban
vegetation
water
* cut -d "|" splits an output line in more fields separated by the "|"
character
* -f3 (belongs to the cut command as well) and prints only the 3rd field
* sort -u does the actual job. It prints only once a name/ number  no
matter how many times it appears.
