[GRASS-user] occurrence of attributes in vektortable
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Mar 7 13:42:35 EST 2008
On Fri, 2008-03-07 at 10:20 -0700, Tom Russo wrote:
> On Fri, Mar 07, 2008 at 03:35:17PM +0100, we recorded a bogon-computron collision of the <nikos.alexandris at felis.uni-freiburg.de> flavor, containing:
So we end up with (in my example using the table "TrainingSamples" and
the column "clccode_le"):
v.db.select -c map=TrainingSamples column=clccode_le | sort -u
Still,
I think it's necessary to give a multiplatform solution (meaning a
solution which works for wingrass as well). So an SQL query should be it
as far as I understand.
Thank you all and sorriezzz if I insist too much ;-p
Cheers,
Nikos
